205 GTI Fore16ver
Re: 205 GTI Fore16ver
Episode 6: Winter sleep
With the weather turning for worse, the last thing I set out to do was removing the engine
block and gearbox to have the engine bay ready for better inspection.
With the only help being provided by two small hydraulic jacks, fighting the lack of space,
adverse weather conditions and unpleasant neighbors, I manage to successfully pull it all out.
This is the point where the front crumpling zone ends (and how far back will the chassis have to be
cut off and replaced), with the rest of the impact having been absorbed by the roof and the floor.
Everything packed up tightly and ready for winter sleep.
Full size photos: http://photos.cybernck.com/205gtifore16ver?page=3
that is a verry large peace you'll have to replace...
not just an easy fix
I will not only have to replace a part of the chassis, but also get the shell straightened up.
Episode 7: Awakening
Most of the 2013 went by without having anything done on the car, purely because I couldn't find
anyone to take on the work of fixing the chassis and rust patches. However, near the end of the year,
it was time to continue the restoration work.
All the rear bumpet bolts were rusted up solid, as expected.
Stripping off the remaining bits in the engine compartment and also the interior.
Only God knows how will I put it all back together!
To be continued...
To be continued...
Laatst gewijzigd door cybernck op ma 10 feb 2014, 23:13, 1 keer totaal gewijzigd.
Nice Rims
Yes, but they're on temporarily, as far as this car is concerned .
Episode 8: One Horse Power
During my hunt for parts, I managed to find just what I need - NOS replacement headlight panels!
I've also finally managed to acquire an "auto bonnet" - i.e. a bonnet off of a 205 Automatic.
It's not in the best shape, but it's crucial for my vision of this car .
Anyway, the second day of dismantling was mostly easy work. The front wings are reusable, but I'm
on a look-out for a pair of new ones - which are proving very difficult to get hold of now-days.
The front part of the floor pan would have been perfect, if it wasn't for a crack from the known crash,
while the culprit for the damage in the rear part were the holes in the tailgate and LPG installation.
There's just a small usual rusty patch under the rear seats.
Awaiting pickup, to be transferred to the bodyshop.
the headlight panels: always rusted
Episode 9: Cut
The car arrived at the body shop and it was time to finally start going in the direction of having a rust-free 205 shell.
The chassis had been pulled back to OEM specification, doors put back on using larger pins and body panel gaps set. Then the crash-damaged rotten corner section was cut off.
Out with the cancer!
Next up, the replacement part I had sourced earlier had to be trimmed and a good inner wing panel fitted back on the car, along with the brand new headlamp panels.
To be continued...
To be continued...
Episode 10: Paste
Ta-daa! Inner wheel arch welded on, as well as the new headlamp panels. Looks infinitely better
than the old mix of filler and rotten metal! Pretty seamless transition of the car's chassis and
the new part - it will look as new when it sees some paint.
The other side has seen some grinder action too. Another culprit and often overlooked area is
the bottom of the A-post.
The fuel tank has been dropped and the floor cleaned up with the boot floor section left to sort out.
Meanwhile, I decided to take a look at my very low mileage XU9J4Z 405 Mi16 engine I bought back in 2007,
that has been removed out of an 405 Mi16x4, crashed 10 years earlier, in 1997, with only 35 thousand
kilometers on the clock!
To be continued...
Full size photos: http://photos.cybernck.com/205gtifore16ver?page=4
To be continued...
Episode 11: Solid foundation
Back at the panel beater's, the car has had most of the major body work done. Facial reconstruction
surgery complete. The red arrows are there to sway your attention towards removable lower section,
for ease of maneuvering the engine in at a later date.
The Automatic bonnet has seen better days, but I'm very happy to see it on the car none-the-less!
Some crude work has been done on the exterior too. The doors are rather rippled, but it will all be
sorted out, when the time comes. The hole in the floor patched, along with a few more in the front arches.
The car stayed at the bodyshop for some finishing touches while I was on a tour around Bosnia,
filling the car up with various 205 parts, including another (and hopefully better) Auto bonnet!
Also, I dug these wheels out, that I had purchased a while ago, with an intention of making
a transportation device for a bare 205 shell, heavy parts such as engines and apparently
cyclists too .
On the last day of 2013, I got the car back, fully rust-free and ready to go to the painters.
I've even had to rent out yet another garage, as the old one got filled with all sorts of parts
in the mean time!
Full size photos: http://photos.cybernck.com/205gtifore16ver?page=5
cyclists too .
in the mean time!
Impressive build
idd, this is one lucky 205
Episode 12: 205. Un sacré numéro.
After a "Winter sleep", in May of 2014 I finally managed to find a bodyshop that has agreed
to do a bare-shell respray of the 205, so it was time to get it out of the garage and do
some more parts stripping and then finally make a move forwards, in every sense .
Only being satisfied with the best results, I decided (and managed) to get new replacement
front wings. Pattern parts, but the ones on the car were also not OE parts plus they have
been a bit rusty as well.
Meanwhile, in one of my other hobbies (cycling, if you are not already aware of it),
I randomly got my favourite number for a starting number in an international race .
Full size photos: http://photos.cybernck.com/205gtifore16ver?page=6
Episode 13: Let there be paint!
Meanwhile, at the paintshop - the car finally sees some fresh Miami Blue paint! Yay!
The whole floorpan has been coated in stonechip and then resprayed in body colour.
Although I'm not really going to go off road with the car, it's nice to have some,
err, protection .
Also, not being satisfied with the two Automatic bonnets I've had previously acquired,
a friend has found me the best one yet! Sweet!
And here's the 4th engine presented in this story so far - rare and iconic XU10J4TE
a.k.a. 220 bhp 405 T16 engine. Although it would have been amazing to have this beast
fitted under the bonnet, it was missing a few things and would have made my project
even longer and more complicated, therefore I decided to let someone else enjoy it!
err, protection .
